ASUS N61JQ-X1 Battery
todd23
I wanted to get a 9Cell Battery for my ASUS N61JQ-X1  but the battery place on eBay says it will not for but only able to use a 6Cell is that true or can I actually get a 9Cell Asus A32-M50   for my laptop as it is in the listing but still says
see below ad
Thank you
1 ACCEPTED SOLUTION
Accepted Solutions
@todd23
The product description comes from a third-party seller on eBay, so the compatibility information may not be entirely accurate.
4 REPLIES 4
Falcon_ASUS
@todd23
The 9-cell battery is larger in size and wider compared to the 6-cell battery, which may be why the retailer informed you that it is not compatible.
todd23
so than it is mostly is it not that it is a 9Cell but it is too thick to slide in to the compartment   but why than they would have in the listing saying 9Cell Battery for Asus A32-M50 A32-N61 N61J N61JA "N61JQ" N61JV N61VG N61VN    like it would work?
Thank you
@todd23
todd23
OK thank you
Have a Nice Day
