04-20-2025 03:48 AM
I could really need some help here because I'm starting to pull my hair out trying to figure out what is going on here.
I have a pair of ZenWiFi Pro ET12 routers. Yesterday, I was informed via the Android Asus Router app there was a new firmware available (3.0.0.6.102_36597). After upgrading both routers to this new firmware version, the router acting as the node ends up showing yellow rather than white and no devices connect to it.
I've tried to pull the power, reset first the router acting as node to factory default settings and then both routers when just resetting the node didn't help. No matter what I do it seems, I end up in the same situation after setting everything up again. With the router showing white color and the node yellow with no clients connecting to it.
What on earth happened here and what can I do to make my setup work normally again?
With big thanks in advance for your assistance!
04-22-2025 03:53 AM
Same here, led is yellow. I too could only reset by the mentioned wps method. Annoying.
04-22-2025 06:46 PM
Same issue after installing firmware version 3.0.0.6.102_36597. Steady white on router, steady yellow on node with web GUI showing "great" connection with 6Ghz backhaul. Unplugged the node from current spot and moved node 3 feet from router and still showed yellow on node which leads me to think the firmware is the issue. To confirm, I rolled back to the previous firmware and both show steady white. Tech support was not able to provide a solution. Hopefully, they will get this fixed soon.
04-22-2025 11:21 PM
Hi @WebMaximus @Lonaav2122 @PeterHouben @navman28 ,
we sincerely apologize for the issue you are experiencing where the router node's indicator light has changed from white to yellow after updating to version 3.0.0.6.102_36597.
To further investigate this problem, we kindly request that you submit the relevant system logs through the feedback function in the router's management interface when the issue occurs again.
Additionally, please confirm whether you have performed a hard reset on the node and the problem persists.
Please follow the steps below to report the issue, and we will assist you:
Additionally, please send us the following information via private message: product serial number, the time the problem report was submitted, the email used for the problem report, the time the issue occurred, the MAC address of your device, and a network architecture diagram of your current environment.
If your network is down, the UI page will generate a link for downloading offline data. Please click the link to download the data, compress it into a ZIP file, and provide a cloud link for us to analyze.
Thank you for your cooperation.
04-23-2025 12:23 AM - edited 04-23-2025 12:23 AM
Sorry, I don't intend to start messing around with this again now when I finally got it working. I already spent enough time solving the issue.
Surely you must be able to repro the issue on your side without help from your customers based on how multiple people have reported the same issue in here.
04-23-2025 01:30 AM
Agree. Been struggling since Sunday. This morning I rolled back 1 node to 3.0.0.4, since impossible to join the mesh until I did a hard reset with wps button. Result: led solid white, all connections fine. I leave it for now!
