09-23-2025 10:51 AM
I have setup the samba. Is working internally and externally.
Now, I have struggled to understand why the samba port is so hardened in the firmware. I can access and map externally because my ISP now allows the port 445. But when I enable the firewall option on the router, is no longer working.
Port forward did not helped ( all the other ports opened externally are working with the firewall on and port forwarding on).
If I SSH into the router, and manually enable the port with iptables -I INPUT -p tcp --dport 445 -j ACCEPT, it works, with the firewall on, but the thing is that this is a temporally rule, after a reboot is gone.
I tried to open the port on the firewall inbound rules on the GUI, but the SAMBA 445 cannot be opened from there.
The only options: 1. Disable the firewall completely ( I don't want that) and 2 - each time enable the firewall rule on the SSH.
Anyone knows how I can enable the SAMBA port externally and still keep the firewall on?
09-23-2025 10:11 PM
I am assuming you've already tried enabling UPnP?
09-24-2025 01:17 AM
yes, I don't understand why the SMB port is so hardcoded into their firewall.
09-24-2025 01:33 AM
Can only guess it has something to do with this CVE:
09-24-2025 06:46 AM
Gotcha bud. But still, when it comes to this, it should by own decision how I chose to secure my network.
Keeping the firewall on, it removes the SMB external access, allowing via ssh iptables -I INPUT -p tcp --dport 445 -j ACCEPT into the router, works till the next reboot, then I'm back with the same issue.
The router does not allow me to create a cron script in order to run automatically after a reboot, so this has so be done automatically via cmd each time. Not a solution. Keeping the firewall off just because of the SMB port again is not a good solution. It should allow users to open the SMB ports properly via the firewall GUI without many procedures. I really want to find another solution, a permanent one.
