MLO are not enabled on all nodes
Dolbic
Hello.
I wanted to inquire how to individually enabled MLO connectivity on all my nodes, I have 5 Zenwifi BT10, 3 out of 5 are using MLO and the rest 2 are using single unlink type.
I tried to do everyone I could, but I could only find a single option that either enable the whole system or disable it, it is enabled but only 3 came into effect.
Alex52
Rising Star II
At this time, full MLO only works between the main router and one node. You may be seeing additional nodes tagged with MLO in the GUI. I saw the same thing in the last firmware update until I did a factory reset.
