06-07-2025 03:25 PM
ASUS posted a new firmware update to help address the issues with the previous FW versions on the BE14000 and BT8 mesh systems. Several folks have upgraded to the 56914 version. So far, so good. If you have issues with the BT8 or BE14000 recently you might want to consider upgrading to 56914.
The one thing we have noticed is that the 56914 syslog has repeated Assoc/Disassoc messages. Have not seen any issues with it though.
Jun 6 09:32:30 hapdevent: hapdevent_proc_event(381): ra2: Disassoc c8:c9:a3:28:c6:3c
Jun 6 09:40:05 hapdevent: hapdevent_proc_event(347): ra2: Assoc c8:c9:a3:a8:d2:be
Jun 6 09:40:06 hapdevent: hapdevent_proc_event(381): ra2: Disassoc c8:c9:a3:a8:d2:be
Jun 6 09:40:21 hapdevent: hapdevent_proc_event(347): ra2: Assoc 3c:e9:0e:c6:32:38
06-10-2025 10:08 PM
Hello
Are you still having good results with your Zenwifi. I have updated but there are still some slowness.
Do you have some recommendations which settings are best? I have changed my settings a lot (beamforming etc) and I don't know any more what is best in current situation. I just would not like to return default settings and create wifi again...
Do you have daily scheduled automatic reboot on? I was thinking to try it next if it stabilizes situation.
06-11-2025 07:14 AM
@Butterfly , I have not enabled auto reboot. I made some config changes - IoT net for Ring, etc., Adaptive QoS with Web Surfing #1, Video streaming #2, MLO enabled.
I have had issues with Ring cams bouncing between nodes so I did binf a few cams to a specific AP.
06-11-2025 06:36 AM - edited 06-12-2025 05:54 AM
BE14000 in Japan
3.0.0.6.102_56914 fixed the issues I had:
3.0.0.6.102_56914 issues I noticed:
I hope the next firmware update will:
06-14-2025 11:01 PM
