PA278CV OSD
baveryret
I have a new-out-of-the-box PA278cv monitor which  does not let me access the OSD. When the monitor turns on, after the initial flash screen, i  see only "display port: no signal". If I press any of the keys to activate the OSD only the "Input Selection" screen with  HDMI, Display Port, USB Type-C, and Auto Detect  is offerred. That happends for any of the OSD buttons on front of the keyboard.  I cannot access the full OSD menu.
I have seen a recommendation to unlock OSD  by pressing and holding the OSD key immediately to the left of the power button ... that seems to have no obvious effect.
Is there a secret hand shake😊 I need to use with ASUS or is my monitor not operating correctly? It *is* new.
Any help is greatly appreciated.
-ba
baveryret
Those OSD keys are on screen bezel, not the keyboard!
