FAQBot
Community Manager
Community Manager
The Installation Guide of IPMI Expansion Card for all Compatible motherboards.
To fully support the functionality of the IPMI EXPANSION CARD, please take note of the following cable connections when installing the IPMI EXPANSION CARD:
1.Use the BMC Cable to connect the IPMI EXPANSION CARD to the BMC HEADER on the motherboard. This connection is necessary to enable real-time monitoring of the motherboard's sensors.
2. Use the SPI Cable to connect the IPMI EXPANSION CARD to the TPM HEADER (or SPI HEADER) on the motherboard. This connection is essential to enable the BIOS Forced Update functionality.
However, the locations of the BMC HEADER and SPI HEADER/SPI TPM HEADER may vary for each motherboard that supports the IPMI EXPANSION CARD. Please refer to the information below to understand the interface (HEADER) locations of the motherboard you are using.
Note: The availability of this feature may vary depending on the specific motherboard. Please refer to the IPMI EXPANSION CARD documentation for further details.
ASUS Motherboard
MB onboard sensor real-time monitoring
Remote BIOS Forced Update
Intel Platform
ROG STRIX Z690-F GAMING WIFI
V
V
ProArt Z790 CREATOR WIFI
V
V
ProArt Z690-CREATOR WIFI
V
V
Pro WS W790-ACE
V
V
Pro WS W680-ACE
V
V
Version history
Last update:
‎10-07-2025 05:32 AM
Updated by:
