FAQBot
Community Manager
Community Manager
[ProArt Station] How to terminate USB power when system shutdown
Please follow the steps below:
BIOS:
1. Power on the system, and press the "delete" key to enter BIOS setting with Advanced Mode (F7), as shown in the figure below:
2. Under Advanced setting, to opt the APM Configuration, as shown below:
3. To set up ErP Ready item as Enabled(S5), as shown in the figure below:
4. Press F10 to save changes and reset, as shown in the figure below:
Under Windows 10:
1. Right-click the windows icon and select [Power Options], as shown below
2. Click [Additional power settings] on the right side of the power and sleep page, as shown below:
3. Click [Choose what the power button does], as shown below:
4. Click [Change settings that are currently unavailable], as shown below:
5. Un-tick the checkbox of Turn on fast startup (recommended),and then click to [Save Changes].
Under Windows 11 :
1. After booting into the system, left-click on the search icon below to search for [Control Panel], as shown in the figure below:
2. Click [Hardware and Sound], as shown below:
3. Click [Power Options], as shown below:
4. Click [Choose what the power button does], as shown below:
5. Click [Change settings that are currently unavailable], as shown below:
6. Uncheck [Turn on fast startup (recommended)] in the shutdown setting menu, and click [Save Changes], as shown in the figure below, you can complete the setting of how to turn off the USB port standby power in the shutdown state.
Q & A
Q: How to confirm whether the setting is successful?
A: After the setting is successful, plug the phone into the USB port and turn off the computer, if the phone is not charged, the setting is successful , If the phone is charging, please confirm whether the above steps have been omitted or the settings have been saved.
Version history
Last update:
‎01-29-2024 05:45 PM
Updated by:
Contributors
