on
10-08-2024
12:42 AM
- edited
Sunday
by
ZenBot
[NUC] Warranty Information for NUC Element Products
See below for warranty information specific to NUC Element products.
Click or the topic for details:
Asus offers three-year limited warranties on NUC Element products purchased from Authorized Distributors. This warranty covers all hardware items included in the box.
Warranty terms
Q24356_ASUS_Small_Computer_System_Warranty_Card_V8_WEB
Date: April 2025
Note: PDF files require Adobe Acrobat Reader*
Chassis manufacturers might design enclosures for NUC Element Products that include passive cooling solutions. To accommodate these types of custom chassis, some chassis manufacturers or integrators remove the fan or otherwise embed the product. In these cases, it is the responsibility of the chassis manufacturer and integrator to ensure sufficient cooling of the modified system to meet the environmental limits as specified in the Intel product technical documentation. Failure to sufficiently cool the Intel NUC Element Product in custom enclosures will invalidate the Intel Product Warranty.
NUC Extreme and Pro Elements are not recommended for use with passive cooling solutions, and the chassis manufacturers and integrators are fully responsible for the risk of making such modifications. If you have a devices that has been modified by a third-party chassis manufacturer in this way, contact the manufacturer's support to determine the device's warranty status.
Make sure you know your Windows* OS Activation number (if applicable).
The table describes what to return and what to keep with you.
Product | Whato to return | What to Keep |
NUC Compute Element |
NUC Chassis Element |
NUC Assembly Elements |
NUC Board Element |
Caution ![]() | Intel isn't able to track or return user-installed components, including items included in the box upon return. Unless otherwise mentioned above, remove M.2 storage and memory modules (if applicable) from your Intel NUC Chassis/Board Element before sending it to our Warranty Center. Where applicable, make sure to backup all applications and data. Intel is not responsible for any data loss occurring from the warranty process. |
Intel NUC Elements sent as warranty replacements don't include a Microsoft Windows* license sticker. If your Intel NUC has a Windows license sticker, we recommend you carefully peel it off the chassis. You can take a photo of it for future reference before returning it to Intel for a warranty replacement. Microsoft Windows stickers aren't available as fulfillment items.
If you have the original retail box, you can use that box to return the product:
If you don’t have the original retail box:
If you’re returning more than one item, protect each item with enough bubble wrap, loose fill foam, or similar cushioning material to prevent shifting during transit.
