Saturday - edited Saturday by ZenBot
[LCD Monitor] ProArt Pen MPA01 Q&A
Below is ProArt pen MPA01 FAQ:
What is Feel by Wacom EMR solution?
Answer:
Wacom EMR (Electromagnetic Resonance) is a technology, and known for its digital pen and tablet solutions. EMR technology is a type of digitizing technology that allows for the precise capture of pen input on various surfaces.
What is the better device to use ProArt pen MPA01?
Answer:
ProArt PA169CDV.
Link: ProArt Display PA169CDV
Does ProArt Pen need battery?
Answer:
No Battery Required: One of the significant advantages of EMR technology is that the pen does not need a battery. The pen is powered by the electromagnetic field generated by the tablet or display, making it lightweight and eliminating the need for battery replacements or recharging.
What’s the difference between ProArt MPA01 and Microsoft Pen MPP2.0?
Answer:
The EMR Solution Pen and the Microsoft Pen MPP 2.0 are both digital pens designed to enhance productivity and creativity on electronic devices, but they cater to slightly different needs and technologies. The major difference. The choice between the two would typically depend on the specific device you are using and the features you need. ASUS ProArt pen MPA01 is compatible with other devices with EMR-technology, such as ASUS Flip C214 Chromebook, remarkable tablet, HP Chromebook, Acer Chrome, Acer Concept D, Dell Chromebook, Fujitsu ARROW Tab series, Fujitsu LIFEBOOK series, and many other devices with EMR-technology.
In summary:
• The EMR Solution Pen is more specialized for use with Wacom EMR technology screens and is known for its professional precision and battery-free operation.
• The Microsoft Pen MPP 2.0 is designed for devices using the MPP 2.0 protocol and requires Bluetooth connectivity for a more integrated experience with Microsoft software.
