FAQBot
Community Manager
Community Manager
[Desktop Chassis] TUF Gaming GT302 ARGB case fan (front/rear) disassembly and assembly instructions
Notice
1. Please, wear gloves to protect your hands before disassembling and assembling, and pay attention to the corners of the parts to avoid scratches.
2. When the side panel is made of glass, please handle it with care when disassembling the side panel of the case to avoid collision/fall/stress.
3. When disassembling, please lay the casing flat on a flat surface to prevent the side panel from falling during disassembly and assembly.
4. Please, tidy up the relevant wires during assembly to avoid damaging the wires during the assembly process.
Preparation
Phillips screwdriver PH2
Compatibility
Preinstall fans information please refer to specification page of product.
Step1. Pull outward and upward to remove the both side panels from the rear groove.
Step2. Release cable ties.
Step3. Replace Fan.
A. Front
(1) Open the front panel upwards from the bottom groove.
(2) Remove 4 screws on each fan, then replace the fan with a new one.
B. Rear
Remove 4 screws, then replace the fan with a new one.
Visit ASUS official website to learn more about TUF Gaming GT302 ARGB https://www.asus.com/motherboards-components/cases/tuf-gaming/tuf-gaming-gt302-argb/
Version history
Last update:
3 weeks ago
Updated by:
Contributors
