No sound - Volume slider
SaranSaran Level 2
edited September 2020 in ZenFone 6
The first five steps of the volume slider don't produce enough sound to be heard making it irrelevant through headphone, can be heard only after increasing to 7 or 8 steps out of 15 steps.
@Anders_ASUS
Comments
  • i agree, i think a recalibration of the slider is needed
  • Same issue here. I'm forced to keep the volume above 10 to actually hear the audio properly. Definitely we need an update to calibrate the sound output.
  • SaranSaran Level 2
    Yes need an update for this
  • It's important you tell me which headphones you are using. With the bundled headphones, you should be able to hear them already on step one.
