Bug : Power saver battery drain detection
NagaNaga Level 1
edited September 2020 in ZenFone 6
Phone show messenger (SMS )  by Google is draining battery very frequently
Comments
  • you should probably post it to Google.. just clear data n cache check... you will loose all messages..
  • NagaNaga Level 1
    It was happening after the update on July 27
  • Hey naga can you send me your screenshot issue and additionally did you install the recent ota without wiping your device?
