Does Zephyrus Duo 16 can using other bland 100W PD charger?
DongheeDonghee Level 1
edited November 16 in Others
  1. System: Windows11
  2. Battery or AC: AC
  3. Model: Zephyrus Duo 16
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
Detailed description:
I bought a Zephyrus Duo 16 recently. I really like using this laptop.
Powerful, reasonable weight compared laptop specs. But the charger weight is way too heavy and big. And I know the Zephyrus Duo 16 can use 100W PD charger. So I wanna buy a PD charger. But can I use other brands of PD charger? I heard that ASUS laptops only allow the same bland charger if I wanna 100W charging.
Comments
