best setting for oled display
zeldaababil01
should i use the flicker-free dimming or not?
everyday i use the laptop at less 40% brightness from windows seeting, so should i am use the flicker-free dimming? then what the best setting for extend the oled
3dmikee
Rising Star I
is there any fatigue at brightness below 60%? if so, set the brightness to 60%-100% in the windows settings, then set the comfort brighntess level in the flicker-free dimming settings
D_IMAN
Rising Star II
I used the laptop at 50% brightness and flicker-free dimming 80% - 90%
And suffered from PWM!
Right now I'm using 40% yaroxy and flicker-free dimming 100%
And so far there are no problems with PWM.
ASUS_Bot
Rising Star II
