ROG Phone 6 Audio stops while changing Volume
LouRaX
Model Name: ROG 6
Firmware Version: latest Update
Rooted or not: no
Frequency of Occurrence: Always
Always lags for 1-2 Seconds while changing Volume Up ... Then the music contunues
5 REPLIES 5
LouRaX
Also Sometimes it stops Spotify playing randomly while lockes
Mattias_ASUS
I have created a rapport to the R&D team.
PhenomFX
Can confirm that.
It also make bluetooth stutter sometimes and lose connection for a second.
Mattias_ASUS
Hello!
I got a reply from the R&D team and they would need some logs to check what could be causing the issue, I would appreciate it if any of you who has this issue could create a log and send it to me as a PM so the team can take a look into it.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Note: When you're no longer planning on logging your device, enter “.09595+=” in the calculator and the log tool will stop as well as deleting all stored log files. Make sure to share via calculator. The files found in internal storage -> asus_log are not the correct files (they are only 1.2kb)
