CPU overheating while IDLE (10% cpu usage), Battery drain in 2H, on Asus Zenbook 15
- System: Ubuntu 22
- Battery or AC: Both
- Model: Asus zenbook ux534
- Frequency of occurrence: Persistant
- Reset OS: Yes
- Screenshot or video:
Detailed description:
The problem is not happening right now on windows. On ubunty, it suddenly became unstable on linux after a boot to windows and back to linux.
I had this problem since the very first day i bought this computer on windows.
On caption below you can see CPU usage is below 10% and temp is 80°..
Fans are on.
0
Comments
Caption of cpu and temperature usage
@adonassayag
We are unable to comment with you on the use of Linux systems.
We will recommend that you install the system as the Microsoft system.
