Does X Mode + work with any cooler like FunCooler or does it require Aeroactive Cooler?
Please note i do not mean regular X Mode, I'm specifically talking about X Mode Plus.
0
Comments
For sure it use only aerocooler becouse you connect the cooler whit your phone and use asus software to control it but that doesn't mean other coolers doesn't help so in this case if you use other coolers you can use advanced settings in armory crate to have better performance
Hello!
To activate X Mode Plus you do require the AeroActive Cooler 5 since it connects to the phone via the pins to the left of your device and unlocks the mode.
Thanks for the reply, I'm struggling to decide which cooler to get.
The best cooler whit the best efect is "black shark fun cooler" go in youtube and watch a video about the cooler for the price this is the best
Only problem is that X Mode + will not work with 3rd party coolers.
Yes this is correct for this reason is better AeroActive becouse he can use Xmode + also he can use a bypass charging and 2 more buttons for gaming
Biggest problem whit 3rd party coolers is that they are not so comfortable and they cant be adjusted so goon on the phone also if they are placed at the middle of the phobe they can incidentally press the buttons on the side and bypass charging is hard to use also the Xmode+ dont work
