Battery draining issue
in ROG Phone 5
Why the Android system using this much battery since the Android 12 update? Never seen this when I was on Android 11. Is it usual for all users?
0
Comments
Hi Mysterio,
What is the SOT (Screen on time) you are currently getting on your phone?
Kindly share the same once your battery reaches 10% and start using the device once the battery is around 98%.
Please also mention the software version of your phone
@ARP_ASUS The SOT I'm currently getting is 5 hours. And the current software version is 31.0810.1226.77
@Mysterio If you are sharing the 5 hour SOT considering the above screenshot, I would request you to share a detailed screenshot where the phone is being used from 100% to 10%.
What Apps are being used. This would actually help analyze what is actually eating up the battery.
