Issues with Outdoor mode, audio wizard, sound quality
lalit.sobhanilalit.sobhani Level 2
edited September 2020 in Fan Chat
There is no difference in loudness when u enable or disable the outdoor mode. There is no difference in sound quality when nu adjust equalizer in audio wizard, no dts experience, new update did not fix any issue. I am highly disappointed with Asus
«1
Comments
  • SOund is definitely better and phone is more somooth now. But update seems just okish. Asus needs to focus on camera now.
  • I do not agree about the sound. Audio wizard is not working, all audio profiles sound same. Toggling the eaualizer does not enhance the audio.
  • @lalit.sobhani this is really strange and unexpected behaviour. Sound is great now. please get your device checked at service centre.
  • I have already done factory reset, even reset the audio wizard, i m still not getting the desired audio quality. The biggest issue is toggling equalizer is not giving any different sounds, its flat no matter u choose classic. Pop rock jazz or whatever. This is a software bug. My phone is not even 6 months old. I would prefer selling it off rather than taking to service center. Did not expect this from Asus.
    Then your unit is faulty cause many other user including me have seen tremendous improvement in phone performance and sound output.
  • Can Asus give a replacement?
  • @lalit.sobhani refer your device to service centre, if they change the faulty parts your device will run properly. If device is within warranty period there is a scope for replacement.
  • lalit.sobhanilalit.sobhani Level 2
    edited June 2019
    I will take it to service center. But let me be very honest about one thing, i m not having any sort of flagship phone experience with Asus 5z. If i knew these problems would come after their faulty updates to phone i would have purchased OnePlus
  • I have a very different experience, Maybe your device is rare case of faulty piece delivered. You can still purchase that oppo device and sell your Asus. Its completely your choice.
  • U r not understanding my issue. I have been using this phone for eight months and i have been enjoying the high quality audio on the same phone without any problem. All the problems started after the couple of updates that asus sent in past few months. This is not a hardware issue. The updates were faulty. Ur sound might be better but its still not the same as it was before. Admit it
  • @lalit.sobhani  I am having a great time with this device and literally have very few demands from ASUS now (Dark mode, AR Core and some 6z camera features). They have solved almost every problem. After every update i clean cache and reboot my device twice or thrice (i suggest you do same for smoother performance as cache f**ks with the performance). Never faced any problem (fingers crossed). I am experiencing better sound with every update asus is pushing. It is better than any smartphone in this range. Except me many other users are also giving positive feedback. I use Evidson (in ear), Sony(Over the head), sennheiser (In ear) and JBL (Over the head) headphones and the sound is so spot on with my custom equalizer setting, i also use wide setting DTS (Try playing with the settings and you will find your perfect setting too). The UI is smooth, crisp and lag free. I dont use Asus launcher and have shifted to evie launcher long back (it leaves me with more than 3gb unused Ram). I am getting around 8 hours SOT and 30 hours standby backup (i dont play PUBG). I use pixelmaster (For wide angle and manual camera) and gcam (modded for 6z for point and shoot). All these tweaks give me a complete flagship experience.  Try some of the above tweaks if you wish. No phone is perfect, we just need to find the workarounds for simple problems. Hope this helps
  • @"lalit.sobhani" what device do you have.
    Is it the same experience with both headphones and speakers?
    edited June 2019
    I figured out the problem. But its still an  Asus issue which they need to fix asap.
     I reset my phone and the audiowizard starting working fine like before. But, when i enroll my phone to Company Portal Intune, device gets encrypted and the audio quality drops again. I had my phone enrolled earlier as well and that time audio was working fine. Its only after the couple of recent updates that the audio quality goes for a toss when the device is intune enrolled and works fine when u remove the intune.
  • ok, which phone do you have, what FW-version and whatever more you can tell me about intune? I need as much information as possible so our developers can try and replicate your issue.
  • Well guys, I don't totally agree with the description but I'm facing some distortions sometimes while playing Pubg mobile, playing streaming music or even Youtube. By the way, game genie is awful in that build.
  • @Willian Rodrigues my issue is not about distortion , its about poor audio quality. Works fine when i dont company portal intune, stops working fine when i i enro my device to intune.
  • I m using zenfone 5z. Firmware version is attached below.
  • @Anders_ASUS Anyone looking into this?
    Yes, I've forwarded this to our software team
    And what did they say?
