Battery draining problem
in ZenFone 8
Battery drainig rapidly...i used to play almost 6 hour of pubg from 100% to 4% now it only last like 2.5 hrs from 100% to 5%... #Asus you should do something about it.... And screen is consuming more power... It used to consume less power before with same frame rate i.e 90fps
22.2% battery for 2hrs 18 min...
0
Comments
Yes mine too...accubattery says that my capacity is only 4000 mah and my normal usage usually last less than 6 hours.
Mine is flip version
Same here after latest update
