Battery drain
Since the latest update my phone drain is ridiculously fast. I used to charge it once a day now I charge it 3 times !!
The screen uses the most of battery by 20% !!! How do I fix this issue ?
Comments
  • @btnan30 First step to find out if something wrong with the battery would be to:
    1. Charge your phone to 100% before going to bed.
    2. Place your device in flight mode, note the time and go to bed.
    3. Check your battery in the morning before turning off flight mode and note the time again.
    That will give you the idle drain / hour, shouldn't be more than a couple percent per hour.
Sign In or Register to comment.
