Coil Whine issues with my Zephyrus G14 - So irritating
- System: ASUS Zepherus G14 - GA401QM
- Battery or AC: Both
- Model: GA401QM
- Frequency of occurrence: Always
- Reset OS: Done and will not help
- Screenshot or video:
Detailed description:Just opened the new laptop and while starting what I discovered is the stupid Coil Whine with this laptop. When none of the fans are running I can hear the audible coil whine and when the fans starts Whine Stops and it's normal.
I bought this laptop for work and don't want that head banging Coil Whine Noise - So what are my options?
I am sensitive to coil whine and this is heartbreaking.
Any good help?
Cheers,
0
Comments
Hi there,
What's you BIOS version?
Please update BIOS and all drivers to latest version.
Hey.. All my BIOS is up-to-date.. yet the problem still lies.. only way the whine goes away is to turn on the fans even they are running in lower RPM.. was looking to a way to use a custom curve with 5% fan speed and not zero
Hi there,
When running the unit, there may some coil whine from the component.
If the whine is still disturbing you, I suggest you go to service center to do further inspection.
