Android 10 beta LOw bluetooth volume glitch
Dhairya
Model Name: Zenfone max m2
Firmware Version: Version WW-17.2018.2004.31
Rooted or not: NOT
Frequency of Occurrence: Permanent ( Till factory reset )
APP Name & APP Version (If your issue relates to the app): each and every app
A bug in android 10, Bluetooth volume is suddenly reduced for no reason. While calling it's normal but while playing any other media the volume is comparatively decreased. I tried everything from safe mode to developer options nothing works to fix it up, the only possible way to fix it is to HARD RESET the device. , just resetting the networks and Bluetooth doesn't work. My headset is completely fine, it's a software glitch. So should I downgrade to android 9 or any stable update for android 10 is near cuz its been several months and still no clue for the same or is there any solution to fix it, nothing on web fixes it...
fussion_ASUS
Rising Star II
Hi there, we'd request you to kindly stay tuned to our channels for more information on the updates.
