that was not meant to happen....2) reinstalled battery. 3) updated keyboard drivers sent by asus support uk. Wondering is there anything else i can try to get it working or based on its age should i consign to the scrapheap? Any suggestions and advice appreciated. Trying to work using an on screen keyboard is painful......
Comments
@loftub1
I have replied to you here.
