vanja - your new phone battery is not in form... you must charge your battery couple times and then battery get in form... after couple months my zf 8 without traveling and only on wifi reaches 10h+ sot with lower brightness, 5h web , messenger, RSS,etc.. only 2g/3g mode.. also using ultra slow charging or even better slower charger adapter stabilize battery life and lifespan..
Ok. I hope so. Im on dinamic battery settings and auto refresh rate,and 4G and android 12. I juste hope what you say is true. Your SOT is crazy good. M SOT is 3-3.5 hours. Its deoressing. I realy like everything about the phone except battery life.
1.Make sure you are running on the latest firmware
2.You can do the following steps to get a better measure of your drain:
Charge your device to 100% before going to bed -> Put your device in flight mode and note the time -> Check the battery level in the morning and note the time again.
Hi,it became better over last 4 days. Maybe charging the phone for 2,3 weeks will unlock the full potential of the battery. Somebody told me that. Also,there are no OTA upadtes and im stuck on November security update.
Comments
So some good people did research on energy consumption and smartphone browsers. There seem to be much more influences than hardware alone.
https://tma.ifip.org/2021/wp-content/uploads/sites/10/2021/08/tma2021-paper18.pdf
What do you mean by that. I dont understand.
Hi @Vanja1986
Report back to us your results.
Hi @Vanja1986
I´m glad to hear that the battery improved.
Also If you are running on an old firmware you can try upgrading it manually, here you can find latest drivers to install Zenfone 8|Phones|ASUS Global
Since you are currently on an older version you will have to upgrade step by step to get to the newest version .92
I just Got the OTA update now. Version 92.it was a small one. Still not january or february security patch. Hope more fixes are comming soon. Tnx
