Battery stuck at 99% and dies at 15%
  1. Model Name:Rog 5
  2. Firmware Version:
  3. Rooted or not:
  4. Frequency of Occurrence:
Comments
  • Does anyone knows solution to this?
  • https://zentalk.asus.com/en/discussion/52994/phone-shutdown-battery-just-below-20/p1
  • Can you please help iam not able to understand from there@k_huat
  • Does your problem solved@k_huat
  • @k_huat please reply
  • @Fahmida please reply?
  • Hi,
    Please try battery calibration.
    To recalibrate battery, charge your phone to 100% without interruption. then discharge it normally till 0% (phone gets switched off). charge it to 100% in switched off condition and keep it in that state for a little more time. now switch on your phone in charged condition and unplug when ASUS logo appears. keep the phone unused for 5 mins.
    Make sure you are on the latest software version which is .210 if not, you can check by
    Go to setting => System => About => Software information.
Sign In or Register to comment.
