Excessive idle battery consumption in Whisper Mode
  1. System: Windows 10
  2. Battery or AC: Battery
  3. Model: UX482EG
  4. Frequency of occurrence: Occasionally on boot
Detailed description:
After days of chasing this issue, I have found that changing from Whisper mode to Performance mode allows the system to use less battery. This appears to be a bug, as you would assume that whisper mode would have lower power consumption.
I am measuring 15-20W battery usage while on Whisper mode and the device is idle, but when I switch to Performance mode (Fn + F) the power consumption comes down to 4-6W when idle and 7-8W during light usage. This is a difference in battery life from <4hrs of idle to ~12hrs of light usage.
Is anyone at ASUS aware of this/working on it? Can anyone else confirm my findings?
Comments
Sign In or Register to comment.
