ZenFone max pro m1
msykp8msykp8 Level 1
edited September 2020 in Fan Chat
Problems after updating..
cannot connect internet..
Comments
  • Yaa bro me to
  • rizvirizvi Level 1
    Just reset your phone,every thing will be ok
  • KamleshKamlesh Level 1
    Some times automatically disconnecting from internet for few seconds
  • msykp8msykp8 Level 1
    Reset all already.. still same problems.. no internet connection..
  • Restart or reboot ur device
  • Ram management issue
  • JunJun Level 1
    Proximity sensor not working when recieving a call... Pls help
  • JoemarJoemar Level 1
    edited June 2019
    I have problem with camera, first open will not working well, you must have to exit first den reopen it again and it works again, so I'll do this again Everytime I will use my cam. Tsk!
    You can clear Cache and data for the camera app from settings and check. If still same issue persist, hard reset the device.
  • Hello all, Please Suggest a solution for Long screenshot , if it is possible on my Asus max pro M1...I have been trying to find a solution over internet but could not find a proper solution. Thankyou .
