Disconnect Bluetooth earbuds with volume problem
k_huatk_huat Level 3
edited December 2021 in ROG Phone 5
  1. Model Name: rog 5
  2. Firmware Version: .196
  3. Rooted or not:
  4. Frequency of Occurrence: frequently
Hi, normally when I connected to Bluetooth earbuds or wired jack headphone the media volume will increase higher a few dB. I have this problem when disconnect Bluetooth earbuds n the volume remain at higher stage (but the media volume indicator already show at decreased level). This happened frequently 6-7 out of 10 times.
I tried to clear cache n memory but doesn't help. The only way to make it back to normal is to restart the phone. This is annoying I have to restart the phone when disconnect the Bluetooth earbuds most of the time.
This problem happens with Bluetooth earbuds AND ALSO the wired 3.5mm jack today (edited from previous post)
Kindly advise. Thanks
