Wacom Pro Pen 2 sensitivity lag when using screen expert
shirahockmanshirahockman Level 1
edited December 2021 in Others
  1. System: ROG zephyrus Duo
  2. Battery or AC: both
  3. Model: GX551QS.404
  4. Frequency of occurrence: ALL THE TIME
  5. Reset OS: WINDOWS 10 HOME 10.0.19042
  6. Screenshot or video:
Detailed description:
When I use the screenxpert control panel with photoshop it causes a wierd lag in brush sensitivity: My first stroke after using the zoom or the brush size dial is always at full opacity / full pressure. the next stroke is as it should be. This is very annoying as it slows down the painting process dramatically. Is there a fix for this?
