CODM : Screen Freeze, Frame Drops and input lag
paijohn77paijohn77 Level 1
edited November 2021 in ROG Phone 5
  1. Model Name:Rog 5
  2. Firmware Version:WW-18.0840.2109.176
  3. Rooted or not: Not
  4. Frequency of Occurrence: Constant
  5. APP Name & APP Version (If your issue relates to the app): Call of Duty Mobile
Hello,
I updated the Software and the game simultaneously last week.
Since the latest updates the game is not running smoothy.
There are constant screen freezes, where the screen will freeze randomly for a second.
The game is choppy and dropping frames.
There are touch input delays.
You will press buttons and nothing will happen for 2 seconds and then all the input commands get fed in simultaneously!
I have deleted the application, data and cleared the cache but no luck.
I have readjusted the settings in the Armoury crate and set the performance on level 3.
I play with the fan attached so no issue of over heating.
Also the cooler trigger buttons won't register the input unless they are pressed repeatedly.
The game was fine but since the Software and the game update it's unplayable.
I am not sure if the game is not optimised for this phone anymore or it is the software update which has caused this issue.
The only major difference I have noticed is that previously the CPU usage would stay between 25 to 35 percent.
Now the CPU usage keep jumping to 55 % straight after the screen freezes.
Kindly look into this, as this
