Problems with "Click" sound, when opening the laptop
nickgabriadzenickgabriadze Level 1
edited October 27 in ZenBook
Hi.
I bought my Zenbook 13 OLED (UM325UA) in august, more specifically on the 26th of August, but I started noticing that while I'm opening the laptop, hinge or whatever it is, I don't know, makes some kind of "click" sound and not only that, but when I'm moving my laptop screen from backwards to forwards, it still does that.
I don't have any problems with closing the laptop though, it doesn't make any sound, but what could be that problem?
Is this a typical thing, which shouldn't be taken into consideration seriously or should I check if there are some problems with the hinge?
Thank you in advance.
P.S I have a 2-year warranty.
Comments
