Lag when on battery mode
billvas2003billvas2003 Level 1
edited October 2021 in Others
  1. System: Asus tuf gaming F15
  2. Battery or AC: Battery
  3. Model: FX506HC
  4. Frequency of occurrence: common
  5. Reset OS:
  6. Screenshot or video:
Detailed description:When the laptop is plugged in it works as expected even under heavy load. When disconneting the power cable minor stuttering occurs while just navigating the os. In the armoury crate app performance is selected. What could be the main reason for this problem? Could a built in battery saver from asus throttle the system this bad?
Comments
  • GPU uses a lot of energy while gaming. So you always need to plug your laptop in in order to play games. That is crucial for all gaming laptops.
  • Hi there,
    The performance of battery mode is not as good as AC mode.
    Please kindly plug in the adapter when playing for stable performance.
