Whatsapp audio problem
- Model Name: Rog phone 5
- Firmware Version: .151
- Rooted or not: no root
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Only on WhatsApp the audio in the capsule is distorted. Only me this problem? I know it's a software problem, when will you release the update to fix it ??
0
Comments
@Moxy Can you share some additional details about your issue? A video recording captured with a secondary device would be ideal.
Hi @Moxy ,
Are you still experiencing this issue?
If so, the best way for us to understand better your case will be a to add video recorded by second device.
You can just added here in the threat :)
I can't send the audio, I solved it at the moment by activating the accessibility setting of the mono audio output. Confirming that it is a software problem to be solved
