Battery icon always shows full battery
- Model Name: ZenFone 6
- Firmware Version: .156
- Rooted or not: No
- Frequency of Occurrence: Always
Battery icon in status bar always shows full battery. Percentage next to it can be at any level, but the battery icon is always solid, indicating full battery. While charging, it works correctly, and fills up as the battery is charged.
0
Comments
Hi @Casper,
Try to clear cache from Asus Launcher and reboot your device.
If it persist I will recommend you to do a factory reset but keep in mind that you'll need to backup your data.
