charging limits at battery care not work like it should.
baster1982baster1982 Level 2
edited October 2021 in ZenFone 6
  1. Model Name:
  2. Firmware Version: 18.0610.2106.156
  3. Rooted or not:
  4. Frequency of Occurrence:
hello I'm noticed strange behavior in "battery care" the charging limits not doing what is supposed to do.
if i limit to 80% and it charge til 80% and than cancel the limitation it immediately goes up to 87-89% in seconds.
same if i limit the charge to 90% after canceling it changing immediately to 97%
if the real Capacity is 97% this feature is useless and we not really protect the battery and Extend the "life" of it.
I'm upload video from today and pictures from yesterday that Explain a problem.
Comments
  • Hi @baster1982,
    Try clearing cache from Asus Launcher and reboot your device.
    Also I will recommend you to do a factory reset but keep in mind that you'll need to backup your data.
