Laptop Battery charging indicator always blinking
System: Windows 10
Battery or AC: Battery
Model: VivoBook S series S430FA
Frequency of occurrence: Always
Reset OS: No
Screenshot or video: Video
Detailed description: I tried to update the BIOS. But could not do it. Got bluescreen error. So entered into safe mode and reinstalled the Version 306 BIOS. After that I am facing issue with the battery indicator. Its always blinking as white when the laptop is powered ON. Kindly help me in this case.
RAJU_MSC_MATHEM
Zen Master I
saravanankumaresan53507
  1. System: Windows 10
  2. Battery or AC: Battery
  3. Model: VivoBook S series S430FA
  4. Frequency of occurrence: Always
  5. Reset OS: No
  6. Screenshot or video: Video
https://us.v-cdn.net/6031231/uploads/A3EEX1H14FP8/video-2021-07-17-10-47-15.mp4
after successful upgrading of new bios firmware, did you reset bios settings to default?
if not means do bios settings to default, and restart the system, then go to bios, configure settings as you need it, then save and exit.
