Ask for solution of Battery consumption is more higher than charging rate in zenfone Max M1.
I'm using my zenfone Max M1 after it's launch in market.
Since a long time I didn't received any update, and still in android 8.
And main problem is charging rate too slow but consumption rate is too high.
0
Comments
Hi there, you may click on the following link to download the update manually, request you to read the instructions before upgrading and take a full backup of the device before. Click here: https://www.asus.com/in/Mobile/Phones/ZenFone/ZenFone-Max-M1-ZB556KL/HelpDesk_BIOS/
Hi, kindly click on the following link and follow the instructions to update manually. Click here: https://www.asus.com/support/faq/1009748
This is only sequrity patch update or android version upgrade.
Kindly confirm this.
Hi, we suggest you to please visit the nearest ASUS service center for better assistance. We request you to call the service center before visiting. Locate here: https://www.asus.com/in/support/Service-Center/India
