Volume key control toggle missing on settings
PaullyPaully Level 1
edited June 7 in ROG Phone 3
Has anyone here experienced sudden disappearance of the "volume key control" setting toggle on ROG 3? Phone was bought almost a month ago, i remembered while setting up the settings that there is a certain control, then when i was about to change something on the sound settings, i couldn't find the toggle anymore, it suddenly dissapeared. Any workarounds or suggestion or any help at all to fix it. Thank you!
Comments
  • This option will find its way back in A11 so don't worry ;)
