Weird fan noise (Buzzing sound)
AerunaxAerunax Level 1
edited May 2021 in ZenBook
  1. System: Windows 10
  2. Battery or AC: AC
  3. Model: Zenbook UX482E
  4. Frequency of occurrence: Whenever fans start to ramp up
  5. Reset OS: No
  6. Screenshot or video: Attached below
Detailed description: Hello, just got myself a Zenbook duo UX482E literally hours ago and when I took it home to set it up, there was a weird buzzing sound coming from the fans whenever the fans start to speed up. Is this normal or should I bring it back for an exchange?
Comments
  • Mine doesn't do that sound, but I don't know how you recorded it, if very close to the vents or not...
    Anyway, if I was suspicious with a brand new machine I would send it to check.
  • Hi there,
    May you bring the device to the seller or to our service center so the engineers are physically check the device?
