Battery drain issue and charging time getting lesser Asus 6z
edited June 2021 in ZenFone 6
  1. Model Name: Asus 6z
  2. Firmware Version: 18.0610.2103.137
  3. Rooted or not: Not rooted
  4. Frequency of Occurrence: Daily
Many months ago my charging cable got damaged so I ordered another type C cable online which was completely working as original cable no delay in charging time & Screen on time. But recently , this cable got some inner damage don't know how . While plugging in into charging it shows only charging not Fast Charging. So I thought to buy a new cable so at that instance I used different cable to charge but for the first time battery gets charged in 1 hrs 30 min I don't know what was happening but as I got good screen on time so I was satisfied but after charging 3 to 4 time phone getting charge in 1 hr 10 min or even lesser infact normally at 90 % phone starts to charge slow but here it was not happening . After that I got the battery draining issue , whenever I keep my phone idle it drains upto 12-13% which is not good. For this I reset my smartphone so if it is happening because of some bug but the results are same , even after charging with cable bought online still it's happening and charging time is getting lesser and battery draining fast. Firstly I was getting 10% reduction in 1 hr in use but now it has also reduced. Please give some solution 🙏🙏
Comments
  • It looks like it has something to do with battery aging. I guess may be your battery is aged and so health of battery may have been reduced to some extent. And so sometimes this is to be the real cause to charge your phone faster than earlier & also drain faster than earlier.
    This can be fixed if you examine your device at service centre to know the real cause of the problem if its really a battery problem.
  • Not much than a year I bought the phone and charging habits graph was also at green (good) not a single notification for any battery problem how it can be a battery ageing problem?
  • Nothing to worry its just my guess though. Lets see what mods have to reply for this.
    As it is related to charging time & less backup that totally points out towards battery and so it was my guess but yes, also in this case factory reset did not help so just a guess nothing else, but i may be wrong too.
  • edited April 2021
    Should I try slow charging or schedule charging from battery care? Atleast there's a chance to get longer screen on time
    Update: I tried schedule charging now only thing good happened is when the phone is kept idle battery is not draining down but battery % at 73% got stuck for much longer time however it is reduced now and working fine ,you can see the battery graph
  • You can give a try but i dont think slow charging or schedule charging will help you to get good SOT because good/bad SOT that all depends on battery health.
  • Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
    1. Charge the battery to 100% & use as per your normal usage pattern
    3. settings => Battery => Check the screen & share the same
    Please follow the below steps that may improve battery backup:
    1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
    2. Adjust sleep time and brightness (Settings > Display)
    3. Boost memory when you see memory consumption is high with no app running,
    4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
    5. Check the following article for more information: https://www.asus.com/in/support/article/604/
  • Isn't the battery drain graph seems to be unusual?
  • Iam facing same problem it took 7 hours to fully charge my finger print also not working after update why asus giving asis giving a problem in every update other mobile companies giving updates without any problem I used vivo Z1 pro for 2 years without any issues but I used asus 6z from one year I faced so many problems I sold my vivo Z1 pro for buying asus 6z now Iam feeling sad why Why sold it asus doing this please fix our problems first time it is irritating with problems to us please fix it as soon as possible
  • Ihar1shIhar1sh Level 1
    Definitely something wrong with your unit i also bought my zf6 exchanging vivo z1pro i don't regret except the bad thermals of this device everything is working fine till now
