Battery drain please solved
NijilNijil Level 1
edited April 30 in ZenFone 6
  1. Model Name: Asus zenfone 3max
  2. Firmware Version: 7
  3. Rooted or not: no
  4. Frequency of Occurrence:
  5. APP Name & APP Version (If your issue relates to the app): no
Comments
  • Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
    1. Charge the battery to 100% & use as per your normal usage pattern
    3. settings => Battery => Check the screen & share the same
    Please follow the below steps that may improve battery backup:
    1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
    2. Adjust sleep time and brightness (Settings > Display)
    3. Boost memory when you see memory consumption is high with no app running,
    4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
    5. Check the following article for more information: https://www.asus.com/in/support/article/604/
