1. Does the issue happen only in Vodafone sim card? If so, please check with your local carrier.
2. If the issue appear with other sim carrier, please check
(1) Does the issue appear right after any system/apps' download or update?
Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check any disturbance from installed 3rd party apps.
Comments
Hi kotholasureshyadav
Thank you for your asking.
(2) Does the issue occur in any specific area? If so, please check with your local carrier or check if there is any signal disturbance in your area.
