Asus G14 cooling system and fan control
in Others
- System: WIndows 10
- Battery or AC: AC
- Model: G401IU
- Frequency of occurrence: Stable to repeat
- Reset OS: yes
- Screenshot or video:
Detailed description:
I want to discuss two of many problems here. They are relating to cooling system.
- AC plugged in, Armoury Crate mode: Manual, close and open the laptop cover, system went to suspend and woke up - fans start pumping, fans change speed from expected to unexpected RPM. I found that other people have the same issue.
- Armoury Crate "manual" fan curves are available when charger is plugged in only . Do I have a chance to see this functionality for "battery" mode? I think so, the best solution - migrate all this stuff to BIOS. Fan curves in bios - a great idea to support other OSs(e.g. linux based).
- In addition, many laptops have option to disable discrete GPU in BIOS, I will hope to see this in futher BIOS releases
1
Comments
Hi there,
Thank you for your answers!
HI there,
What's your BIOS version?
Before you close the lid, how did you set the manual mode? you set the fan to which %?
and how long did you close the laptop? the laptop went to sleep mode or hibernation mode?
You mentioned unexpected RPM in the first feedback, so what's the RPM it reached? and the device temperature at that moment?
Hello,
BIOS version 219.
I tried a few random percentages from low to high, I suppose it's not related on special value.
I close laptop and open with 1 second delay(sleep mode).
I see 2400-2600rpm in HWMonitor, but i'm not sure is it real. Suppose, HWMonitor registers fan speed values with some tickrate(100ms, 200ms or any) and ignore a intermediate values(between ticks). I counted 2-3 pumpings per second while I was observing the pumping effect. Temperature sensors in HWMonitor displays about 40-45 degrees(celsius).
Thank you!
Hi there,
How about the temperature and RPM in Armoury Crate?
2400-2600 rpm is actually pretty low, as the fan can go up to 6000 rpm when really hard loading.
