Sound problems
- Model Name:ROG 3
- Firmware Version:Touch panel version 06.00.00.30 CFG:43
- Rooted or not: don't know what is this mean
- Frequency of Occurrence:N/A
- APP Name & APP Version (If your issue relates to the app):HDMI sound while use Streamlabs
Yeah I got problem in sound while use HDMI for streamlabs and also know we can stream direct from Phone but this looks so basic and I already got streamlab and setting. While I use same setting for iPhone it works but for Asus Rog 3 it doesn't work the problem is it give sound to both headset and device itself which I don't need. I use Asus Rog 3 for PUBGM so, please let me know the best way to solve. While I browse to YouTube they recommend splitter but I already in splitter but still not working. Please let me know ASAP
Thank You
Pramod
Comments
Impressive setup! Thanks for the whiteboard layout, I'll check and get back to you.
Sorry to ask but the photo quality is quite impressive...
Which device you used to take the above pictures??😁😅
I used Asus Rog 3
@gurungpramod6 With everything set up, what does it say if you check your media output settings?
Press volume up button -> Tap sliders button -> Tap 'Media output' (icon with pointing arrow)
Changing that setting might solve your issue. If not, please let me know.
