Aero active cooler stops working for specific model of Sony headset
edited February 2021 in ROG Phone 3
  1. Model Name: Asus ROG phone 3. Non-tencent version
  2. Firmware Version: 17.0823.2012.131
  3. Rooted or not: No
  4. Frequency of Occurrence: 100%
  5. APP Name & APP Version: PUBG mobile(Runic)
As soon as I connect my Sony headset WH-1000MX4(either using 3.5mm jack or bluetooth), the aero active cooler fan stops after 5-10 secs
It is a problem with only this model, I have wired Sony MDR-XB550, it works fine with it. When I disconnect WH-1000MX4 and connect MDR-XB550, the fan starts working. I have even tried with Apple air pods 1 over bluetooth, and it works fine with it too.
Basic troubleshooting I have tried:
  1. Reboot the device multiple times.
  2. Disconnect / Reconnect bluetooth
  3. Clear Cache of Armoury Crate
  4. Attach / Re-attach multiple times
  5. Allow device to cool down
It is an amazing Device you guys have built, but I would really like if I could use my 350$ headsets with it, which I just bought, and now quite let down due to this
Let me know what more info you need.
Comments
  • It has to be that the mic is somehow being used (There's a setting for the cooler to disable when mic is active). I currently have the WH-1000xm3 and I do not have these issues with bluetooth or wired. There isn't much difference between the two different headsets.
  • It has something to do with the option for the Aero cooler, you might want to disable the Fan to turn off while mic is running option.
  • >There's a setting for the cooler to disable when mic is active
    Is this only applicable for Aero active cooler 2? I have seen threads online for these, but cannot find this option for me in three dots => Settings => Disable cooler when mic is ...
    I have Aero active cooler 3, and ROG phone 3
    Its upgraded headset, although built on mx3, there are hardware and driver upgrades too, which cannot be ruled out for causing issues
  • Update:
    I just found the option "Disable fan when mic is active" in Console => Fan speed
    And it was turned on 😓
    Wondering why it still worked for airpods, but thanks for pointing it out guys. I will update if it does not work
  • @abheeshek.agarwal
    Did you turn this off?
    You should turn this off and try again.
  • @abheeshek.agarwal Did the proposed fix work for you?
  • Yes, the fix works.
