How to restore apps to their default Auto-start setting?
You can restore the apps to their default Auto-start setting by doing the following:
- From the Auto-start Manager screen, tap
, and then tap Restore to initial configuration.
- Tap Reboot device to restart your device and to set the auto-start apps to their initial configuration.
- After restart, launch Auto-start Manager then tap OK on the Notice screen to view the apps to their default auto-start configuration.
Note: This screen appears every time you restore the auto-start apps to their default configuration.
0
