Problem with my X73s Bluetooth
- System: Windows 7 Home Prem
- Battery or AC: Both
- Model: X73SV
- Frequency of occurrence: From the first use to this moment
- Reset OS: Yes (I guess!)
- Screenshot or video: No!
Detailed description:Hello friends, my problem is that I am unable to use (or activate at least) the Bluetooth of this pc, I updated the drivers, I downloaded multiples drivers from many web sites (including the original), but I still can't see it (It doesn't appear in device manager, or anywhere else).
So I would like to know if the problem is hardware or just software, or if this pc model has built-in Bluetooth.
0
Comments
Hello Yah,
I'm afraid that this model does not have bluetooth initially.
Thank you, I was afraid to hear that, but... is there a way to add it (not the USB)
Hello Yah,
Well...I'm afraid that an external bluetooth dongle it's the easiest way for you.
