Battery Drain Issue on my new ROG 3 Phone
- Model Name: ROG Phone 3 ( 8GB / 128 GB)
- Firmware Version:17.0823.2012.122
- Rooted or not: Not rooted
- Frequency of Occurrence: Everyday
- APP Name & APP Version (If your issue relates to the app):
Issue - Battery drain is bit faster on my ROG Phone 3 . Been using the phone at 60 fps to save battery but not working as expected.
Troubleshoot : Tried restarting the phone. Closing background running apps. No improvement in battery performance seen. Need further suggestion for troubleshooting.
Please help me fix the issue at the earliest as it seems lots of owners have reported the same issue after certain firmware update.
Awaiting team's reply.
1
Comments
disable the 5g modem, it's the typical culprit for bad battery life.
Hi, can you share the SOT(Screen on Time) after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Even I'm facing same problem. Normal browsing is also draining battery fast. Please fix this issue with an update.
